1 pipe steam- watter hammer
LDiglio
LDiglio Member Posts: 3
can anyone suggest how to get rid of water hammer in a 1 pipe steam heat system?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,672
    Yes, go here:
    Water hammer
    It pays to wander off the Wall.
    Retired and loving it.
  • chuck_6
    chuck_6 Member Posts: 107
    Water hammer
    It could be a few things, but make sure the radiator is pitched properly. Where the pipe comes out of the gfloor should be lower than the opposite side. The opposite side should have the air vent on it. Also make sure the pipe coming out of the floor is straight.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    And if the hammering is not in the radiators
    what part of the system is it in? When does the hammering occur- when the boiler first starts up, or after it has run a while, or when it shuts off?
  • will smith_4
    will smith_4 Member Posts: 259
    Boy-
    Could we go on about this one!
