Hey Jim, here's that wall rad . .finally
Jim Bennett
Member Posts: 607
Daniel,
Funny thing is, they were supposed to be adjustable.
Had a little communication snafu with the fabrication shop. They already had 50 done so we got them at a reduced rate and worked with them.
With careful planning they do the job.
Cheers,
Jim
Cheers,
Jim
Those brackets worked great. The only thing that would have worked better would be the adjustables that A&R co. produced themselves. I doubt I would ever find those . .
Next time I'm up in Webster I let you know. Take care.0 -
Wall radiator brackets
The whole installation is quite a sight to behold.
Question: From what parts are these brackets fashioned? I tried a "search" but came up empty. If you could direct me to the thread where this bracket system was discussed that would be wonderful. I have to remount a number of these which were removed many years ago but will have to go back in place. Naturally, the brackets are missing.
-TerryTerry T
