pneumatic wood staper
Heatman_2
Heatman_2 Member Posts: 65
Does anyone know a good place to purchase a stapler for attaching 1/2" tubig to floor decking?
  • Yooper Rick
    Yooper Rick Member Posts: 22
    Stapler
    Uponor makes a pneumatic wood stapler. Part# E6021638 if you deal with Uponor. Uses 5/8" thru 1-1/4" staples with a 1" crown. Hope this helps.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    staplers
    We use Bostich tools, available anywhere. Nothing against Wirsbo, I use it all the time, but I find it amuzing, and too expensive to buy their tools. You would think that all manufacturers would make tools available to professional installers at more reasonable prices. But then again, this is a bottom line based economy.
  • hr
    hr Member Posts: 6,106
    Most of the pneumatic
    tool manufactures offer a tool to drive that size staple.(1"crown 1-1/4- 1-1/2" length.)
    I like the Senco PW stapler, although the model may have been replaced or updated? Inexpensive, bulletproof and easy to rebuild. The Senco staples also fit DuoFast and Hitachi brand staplers.
    If you have a contractors tool store nearby try some on for fit. I would guess, like drills or any other power tool, it's more a choice of fit and feel then quality or workability.
    You should be able to rent or borrow a demo from a radiant rep, supplier or manufacturer.
    Used staplers are fairly easy to come by at repair shops. Or pawn shops :)
    If you go with a Senco from a local tool supplier Watts Radiant sells various nosepieces for different diameter tube as well as a handy extension handle.
    hot rod
  • Heatman_2
    Thanks for the help guys
  • Ted_5
    Ted_5 Member Posts: 272
    HeatLink
    sells one. I could get you a good deal on one! Are you in Iowa?
    Ted
