Trane Scrolls
mtfallsmikey
Member Posts: 765
Also, what size Intellipak's are you working on? Mine are 100 ton, 2 compressors are manifolded together. I was unaware of that situation when I first started working here, and was pointed out by a certified Trane tech.
Trane Scrolls
Hi all,
Anyone heard of an unloader in the Trane scrolls? I was working on some Intellipaks, doing PM's and didn't like the pressures and temps I was getting. Called the boss, explains that trane scrolls have unloaders and that's why low suction and discharge pressures.
I know that I'm tired and such, but low suction is not a symptom of a compressor being unloaded is it? I think I would have the oppisite, high suction and low discharge, not low, low.
But I digress, auto unloaders on any scroll is a new one on me!!
Thanks
Don in MO0 -
Hey Don?
It's not an unloader per say it's more of a capacity control 50% then to 100% it's done thru a plate that engages the scroll or bypasses the discharge. There is no adjustment nor control. It's like a Y1/Y2 thing. I know York has it, but let me look for my info and I'll post it.0 -
Mike, find
anything?
I know about the Copeland capacity control. I have a Carrier heat pump. When needed the solenoid is acitivated to engage the total scroll plate. If I remember, 1/3, 2/3 capacity control. With Carrier, the interface controls the solenoid.
What I am talking about is auto-matic, or am lead to believe.
Thanks
Don in Mo0 -
Here Tis
They are Trane SFHFC554P710A59D, 4 Units. Comp # are, CSHA140k0E00.
4 compressors, 2 manifolded together.
Don in Mo0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 988 Plumbing
- 389 Solar
