pneumatic wood staper
Heatman_2
Member Posts: 65
Does anyone know a good place to purchase a stapler for attaching 1/2" tubig to floor decking?
Stapler
Uponor makes a pneumatic wood stapler. Part# E6021638 if you deal with Uponor. Uses 5/8" thru 1-1/4" staples with a 1" crown. Hope this helps.0 -
staplers
We use Bostich tools, available anywhere. Nothing against Wirsbo, I use it all the time, but I find it amuzing, and too expensive to buy their tools. You would think that all manufacturers would make tools available to professional installers at more reasonable prices. But then again, this is a bottom line based economy.0 -
Most of the pneumatic
tool manufactures offer a tool to drive that size staple.(1"crown 1-1/4- 1-1/2" length.)
I like the Senco PW stapler, although the model may have been replaced or updated? Inexpensive, bulletproof and easy to rebuild. The Senco staples also fit DuoFast and Hitachi brand staplers.
If you have a contractors tool store nearby try some on for fit. I would guess, like drills or any other power tool, it's more a choice of fit and feel then quality or workability.
You should be able to rent or borrow a demo from a radiant rep, supplier or manufacturer.
Used staplers are fairly easy to come by at repair shops. Or pawn shops
If you go with a Senco from a local tool supplier Watts Radiant sells various nosepieces for different diameter tube as well as a handy extension handle.
hot rod
Thanks for the help guys0 -
HeatLink
sells one. I could get you a good deal on one! Are you in Iowa?
Ted0
