Hoffman 500 Vents??
paulk
Member Posts: 15
Hello All-
Appreciate any help you could offer. I'm on a single pipe steam system. At some point prior to my owning this home, the previous owner did a bathroom renovation where they replaced the original radiator with an in-wall convector. It's currently not drawing heat and I suspect that the vent is to blame. It's a Hoffman 500 and I'm just wondering if that's what I should be looking for to replace it. Thanks in advance.
-Paul K.
-Paul K.
i would recommend
a gorton vent as your best replacement of that cough, cough, vent..even the standard hoffman 40 is better than that piece of crapola.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
thanks
Thanks for the reply Gerry. I have replaced all the other vents in the house with Gortons and have been really happy with teh impact on the overall system. I just wasn't sure that i could use the same type of vent on the convector- it's the only one in the house and I'm just not familiar with how they work. Anyway, i'll give it a shot. Thanks again.0 -
does it stand vertical?
if so, you'll have to get a convector vent, as opposed to the angle radiator vent..its the same thing just straight instead of a 90 degree pattern.
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
