MAVES One Pipe Steam Vent
Long Beach Ed
Long Beach Ed Member Posts: 1,738
Found this M.A.V.E.S. one pipe steam vent on the Internet.
http://mavessteamvent.com/
Spoke to the man who makes and sells them and who says they come from the USA. He says his vent has no float, has a bimatallic strip and is set to close at a much lower temperature than most others, saving massive amounts of energy. After giving the third degree he said he'd send me a sample, but that didn't happen.
Sounds like he makes them in a garage in North Carolina.
Anyone know anything about these?
Ed
  • John Van Hoesen
    John Van Hoesen Member Posts: 91
    I'm confused... if it closes sooner, doesn't that potentially create an issue... Won't it close before all the air is out? e.g. - the point of it closing at 212 is that you KNOW you have steam... Weird.
  • Long Beach Ed
    I believe...
    ... most steam vents actually close at about 180.
    Maves Guy tells me that "you don't need the whole radiator hot," so the thing closes early.
    Less heat, less fuel, I suppose. Don't really think it will amount to much of anything.
    Just can't figure what would make someone go out and manufacture these. My wholesaler can't get a sample from MAVES MAN either.
    Ed
  • will smith_4
    will smith_4 Member Posts: 259
    Ed-
    Maybe HE doesn't need the whole radiator hot, but it sure seems as if MY customers do-lol. Wonder what the max pressure/drop away pressures are.
  • soot_seeker_2
    soot_seeker_2 Member Posts: 228
    Strange to me.
    Whith the few good products out there at fair prices, why would someone start up a business like this, then not answer serious questions or return calls?
