Modine hydronic unit heaters
G Averill_2
Member Posts: 48
Would anyone have a spec sheet on older Modine hydronic unit heaters to show capacity, cfm and electrical voltage and phase for models H31-21 and H51-21?
Your help is appreciated.
Thanks,Greg.
Thanks,Greg.
are you sure
about that part number?
modine has a list of heaters (1927-present), and those numbers aren't listed.
http://www.modine.com/download/4a370ff12d0c25a2bb52e7da98048c1d/1-455.pdf0 -
are you sure
about those part numbers?
modine has a spec sheet of s/hw heaters (1927-present), and those numbers aren't listed.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
