Modine hydronic unit heaters
G Averill_2
Member Posts: 48
Would anyone have a spec sheet on older Modine hydronic unit heaters to show capacity, cfm and electrical voltage and phase for models H31-21 and H51-21?
Your help is appreciated.
Thanks,Greg.
Thanks,Greg.
are you sure
about that part number?
modine has a list of heaters (1927-present), and those numbers aren't listed.
http://www.modine.com/download/4a370ff12d0c25a2bb52e7da98048c1d/1-455.pdf0 -
are you sure
about those part numbers?
modine has a spec sheet of s/hw heaters (1927-present), and those numbers aren't listed.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
