Installing tekmar 510
Steve D_7
Steve D_7 Member Posts: 10
I am interested in the 510 thermostat and have some install questions.
My current programmable is 2 wires. Do I need 4 wires or can the tekmar work with 2? The boiler / pump control is integrated in my boiler. Where to the 24V contacts tap on a W-M transformer - there are many taps?
How does this compare to the honeywell overall - programming and system control?
Thanks, I know this is the busy season but appreciate any help.
Steve
  • Terry
    Terry Member Posts: 186
    atleast 3
    you'd need at least a 3 wire.
    4 Wire if the heat relay is to be dry contact.
    it needs constant power (C&R), thats 2.
    and you can jump C to one side of heat relay and run the other side of heat relay back to trigger device (min. 3 wire total)
    gl.
    EIN
  • Steve D_7
    tekmar vs visionpro
    I do have 3 wires on my stats.
    As I see the difference, tekmar has the ability to use an "auto" setting for cycles per hour. The Honeywell requires a setting. Which is preferable?
    The tekmar is PI control. Is the HW PI or PID? Does tekmar lose its settings when power goes out?
    What do I give up with different versions of the vision - pro vs retail.
    Thanks
    Steve
