pump purge question
JeffD
JeffD Member Posts: 41
I'm assuming you mean a fuel pump on an oil burner? If so you would use fuel oil to prime the pump.
  • tm
    tm Member Posts: 125
    It says in my book "to protect the pump gears it is advisable to lubricate the pump prior to purging a lift system and to apply oil through the vacuum port". What kind of oil do I use for this?
    Thanks
