kick plate heating
David Sutton_6
Member Posts: 1,079
if propery sized for the load, they can be piped in using mono flo or as a seperate system they warm the floor very nicly,they make noise the fans can loose a bering and get real loud. need to be able to get to it for bleeding from time to time. all in all if room is a problem they work good, a better idea but more costly is underfloor radient heating,
Kick Plate heating
Hi, I'm new to this site. I am renovating my kitchen and will lose the slant fin system in the room. The contractor suggested using a kick plate heater/heating system. Am looking for pros and cons.0 -
I have one in my kitchen and love it...it has a bleeding valve on the front. it dumps heat.
TJust a guy running some pipes.0 -
Tim
What brand unit do you have?
I like the Turbonics ... T4/5, problem is the fan turns on when it senses the water at 137-140, and durning the shoulder months my water temp is at 130 and much less where the kickspace will be installed. Unless I change the temp sensor.
Neil0 -
VRV Products,(VRVP), Quiet One. It comes on about 140 or so, and has a 'regular' or 'boost' fan setting. The 'boost' revs the fan higher and dumps heat. Works well for my kitchen, off of a 2-pipe hot water system. It is tapped off the main loop in 1/2" and does well. We are pleased with it.
- 109 Chimneys & Flues
- 972 Plumbing
- 386 Solar
- 17 Recall Announcements
