Propane BTU calculation?
Al Letellier_9
Member Posts: 929
There are approx. 91,000 BTU's available in a gallon of propane, so multiply 2.4 x 91K and you get 218,400 BTU....at 100% efficiency.....multiply that by the efficiency rating of the unit to get approx. BTU consumption.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Propane
How do I convert the following information into BTU's?
88 cubic foot per hour / 2.4 gallons per hour Propane.
> BTU's?
> per hour Propane.
> _A
> 289&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Isn't Propane 91.6kBTU/Gallon?
... so looks like 220kBTU/hr...
EDIT: Looks like Al beat me to the answer! :-P
Ah, the joys of a laggy internet connection and tabbed threads...0 -
Could be
Constantin, but who knows for sure that it is to spec. We figure #2 oil at 142,000, but that may not always be the case.0 -
Supposedly it is........
There is however, variation in blends that yield different btu/gallon numbers. I was told by a large local propane company to use 90,000 to be safe. They sell over 6,000,000 gallons per year so I assume they know whereof they speak.0 -
BTU values
The stated BTU values are a function of the vapor density/ specific gravity. The heavier the fuel, the higher the BTU rating. Same with NG. Depending upon where you live. Around Philly, PECO says use 1050 BTU/ Cu ft. That, however does not take into account "spiking" during high demand periods where they toss in whatever is lying around on the back shelf---butane, ethane, iso-ethyl whazzamattathane. You name it. Of course, they'll deny it or play it down but just wait until the LNG flows. Get out your Wobbe Index numbers!
Timmy? Ed?0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
