heating systms
Josh_10
Member Posts: 786
Hey Jason, feel free to take a look at my website. It shows many different methods for installing radiant heat. One may be what would make you change your mind..
http://www.seattleheatingcontractor.com/radiant_floor_heating.php
radiant heat
im replacing the heating system in my home and have a few questions.
1. I really like the floor radiant heat but the house is on a crawl space. I recently heard about the system that can be installed from the inside. What do you know about the application, cost and look of the finished product?
2. If I decide not to go with the floor radiant heat my second choice might be the european style panel wall heaters because after my research I found that they take up less room, cleaner because they are off the floor, radiate heat 85% horizontal 15% up wall or vertical, much more efficient because I can control the heat much better with from a valve located on the radiator. Are these findings true? Also, should I go with cast iron radiators verse steel?
3. I just purchased a used wood burning fireplace insert for my brick fireplace. The brand name is quadrafire and I believe it is made of steel. I later found out that cast iron radiants much more efficient? Is this true?
thank you so much for your help. If you would like to speak to me, I can be reached at 518-441-0538.
Jason
- 62 Biomass
