Chase probing
I need to test a horizontal chase to see if 3/4 copper will make it through. There's lots of clamps and framing in there so something that isn't straight and rigid keeps getting hung up. Problem is the chase is 18' long and the room that accesses it is only 7' long, so I need multiple lengths of max 7' with couplers that don't increase the diameter, and that allow it to be pulled back out. Are there any commonly available things, like broom handles that screw into each other, that I can use?
thanks,
jim
  • Bob Harper
    Bob Harper Member Posts: 1,108
    chimney sweep rods
    Call your sweep buddy. He should have an assortment of rods that would work.
  • Adam_12
    Adam_12 Member Posts: 39
    Have you tried fish tape?.How about using a laser pointer to see if you have a route to fit the pipe.Can you use pex pipe ?.Or you could use 1/2 threaded pipe with couplings about 6 feet long.Once you pull the 1/2 inch through have a soldered 3/4 by 1/2 mip threaded into the 1/2 and then pull ithrough the chase.
  • Weezbo
    Weezbo Member Posts: 6,231
    Pex can make it thru in one piece....
    burn a fitting on 18" of copper attach it to the pex...send it thru with a 3/4X1/2 with a 1/2" capthen when it gets to where you want it to be take the reducer and 1/2" cap off ty the copper back in to whatever and go With it.
  • Kevin Zale
    Kevin Zale Member Posts: 1
    6'
    Six foot bull float handles, Ask your mason buddy.
    kevin
