Saw a couple of real death traps today!
Hey, you mean a tank like this?<BR>Lots of these around.<BR>Bet this draft control worked <i>real well</i> too.<BR>But that`s gone, a Prestige is in there now.<BR><BR>Dave
Death traps
I was touring some real estate today with friends looking to buy a house and saw some amazing stuff.
Worst: a boiler which someone had added a shutoff valve after the T&P valve. WHAT IS THE MATTER WITH PEOPLE? The diapragm type expansion tank was sideways, piped in 1/2 copper and "supported" by a 2X4 propping it up. HWBB throughout the house, piped pretty sloppily but probably fully functional.
Next worst: A hot water heater with a yard long horizontal flue pitched down! Didn't appear to be spilling, but even so, not good.
It really makes you wonder what might be lurking next door.
Nathan0 -
"my" expansion tank was much worse; it must have been on at least a foot of 1/2" pipe!
Is the problem with the draft control that it's not set horizontally square to the flue pipe? (I'm used to the hood style with natural gas atmospheric burners)
Nathan0 -
That's right
it has to be level to work properly. You can see where someone did a combustion test at some point, wonder why they didn't catch the regulator problem?
Thanks Frank,
this small boiler room contained an E20 conversion burner, and a Superflue DV water-heater with no C/A supply period!!
That test-tag was put there by the gas utility in Feb/06.
Dave0 -
Good place for an indirect
you only have to supply enough CA for one burner.
Thanks again Frank,
but as I said, there is a Prestige with indirect now, the guy loves it.
Dave0
- 167 Indoor-Air Quality
