Black pipe for potable water!?
adambuild
adambuild Member Posts: 420
Just looked at a basement bathroom estimate and noticed new black pipe supplying hot and cold water for the laundry sink! Where in the code is this nixed?
Thanks, Adam
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    Black pipe
    Malleable-Iron (black pipe) is never used for domestic potable water applications.
    In New Jersey, we use The 2006 National Standard Plumbing Code. Section 3.4 Potable Water Piping; 3.4.3 Water Distribution Piping which refers you to Table 3.4
    Robert O'Connor/ New Jersey
  • Dennis
    Dennis Member Posts: 124
    Black iron
    I am sure that was a typo on the estimate, unless the contractor is from Russia or something
  • bob young
    bob young Member Posts: 2,177
    PROBABLY MEANT BRASS PIPE. TYPO ERROR
  • Daniel_3
    Daniel_3 Member Posts: 543
    I always thought about using the straws for the supergulp from 7-eleven.
  • adambuild
    Sorry guys, I should have been more clear. I went to measure a bathroom job and while in the basement, I saw brand new black pipe supplying a new laundry sink! It gets better: I asked the h/o and he said the home inspector that inspected their new home this summer installed the pipe!? What does the NJ code state specifically?
    specifically
    2006 NSPC; Section 3.4 POTABLE WATER PIPING- 3.4.3 Water Distribution Piping
    Water piping for the distribution of hot or cold water within buildings shall be of materials listed in Table 3.4.
  • Daniel_3
    I though about using some straws from the supergulp at 7-eleven and attaching them with bubblegum, best straw dope yet. . . .
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Forget codes!
    And material specs...what's gonna prevent this from rusting out?...
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Leave your
    business card after you do the bathroom remodel, Adam as that piping will need to be replaced SOON.
    It would be interesting to know if that inspector, if he actually did do the work and not the homeowner, is a plumber? I sure hope not but you should be careful depending on the owner being completely up front with you especially if they or a relative did the work.
    Jack
  • ALH_4
    ALH_4 Member Posts: 1,790
    Iron
    The same thing that prevents galvanized pipe from rusting out? ;-)
