CO Snake oil?
John R. Hall
John R. Hall Member Posts: 2,245
I didn't realize my ignorance -- 90 percent of HVAC contractors don't perform combustion testing? Check this video out.
http://www.youtube.com/watch?v=wKsHnsvX35I
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    That might be accurate
    Most times when I see a test hole drilled in the flue pipe on a gas-fired unit, it's one that Gordon or I drilled.
    Did you see the down-pitched flue pipe on that one water heater?
  • Mitch_5
    Mitch_5 Member Posts: 102
    Just saw the video and sent the link to all I know in the trade
    we have the home owners sign a consent form for us to test. You would be amazed how many people refuse since they do not want there equipment back on. They feel since there is no problem now (so they think) why look for one!
    The video is a definite must see.
    Mitch S.
  • Couderay
    Couderay Member Posts: 314
    C.O.
    A must see scary scary scary. Never heard it explained this way but makes a lot of sense. Rusting and its locations on heating equipment all of a sudden makes sense.
  • Ted_9
    Ted_9 Member Posts: 1,718
    CO
    I'll definitely be paying more attention.
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Read through the replies
    The REAL scary part is the HVAC guys telling this poster that he is full of it. CO testing is a waste. Code prohibits drilling test holes in flue pipe. Testing is a waste of time. Etc Etc Etc.
    Truly sad
  • Jim Davis_3
    Jim Davis_3 Member Posts: 578
    Testing should not be a customer choice
    Without testing we have no clue how anything is truly working. It is the difference between a hacker/fly-by-night and a professional.
    Does a doctor give you a choice on whether he takes your blood pressure, or does x-rays etc.??
    We use our reclaim machine on A/C without a choice and it doesn't make it the A/C run better but here no one has a problem???
  • Mitch_5
    Get it put in the code book.
    I have had several upset people that I shut down. They have the gas company and others check and say well its drafting, all the co is going up the chimney and they turn the equipment back on and walk out the door.
    Remember can't see or smell co so they think its been working ok now so why bother.
    Unfortunately without written permission to test. In there eyes if I am changing a circ or other such item what right to use my analizer then say sorry no heat and by the way you need a new boiler. Few of the authorities of jurisdiction will back us up.
    Mitch S.
  • Jim Davis_3
    Codes = D-
    That is what I like about the video. It really makes the consumer feel like he is getting a raw deal if the contractor doesn't test and puts the consumer on the spot. Every contractor should down load it on their laptop and show their customers. All of a sudden they may be grateful they are using your services.
    As long as codes continue to be a D- grade, just barely passing, combustion testing will never be considered.
