What kind of fittings
ddlong1286@yahoo.com
Member Posts: 139
Hi all,
Went to change the pump Fri. and the new pump had a different size fitting, so back in went the old pump.
The fittings seal to the pump with o-rings and do not have tapered threads, though a 3/4 NPT fitting does screw into the threads, but won't seal.
The flange fittings also seal with a o-ring.
Looking for a name that I can call a distributor and ask for a fitting. sometimes describing doesn't quite cut it.
Thanks Don in Mo
Thanks Don in Mo
BSPP ?
Could it be BSPP? British Standard Pipe Parallel thread.
Both NPT and BSP 3/4" pipe has the same thread pitch of 14 TPI. The peaks and valleys of the BSP threads are rounded instead of flattened like NPT.
Larry C0 -
You Are Correct!!
I was able to talk to the manufacturers USA rep today and he told me that they are indeed 3/4 BSP threads in the pump.
Now if I can find out about the fittings on the old pump and where to get them!
Don in MO0 -
try -
a hydraulics supply house. Sounds like a JIC fitting with o ring.0 -
BSP to NPT adapters
Try the McMaster-Carr site for BSP Tapered to NPT adapters.
http://www.mcmaster.com/
If they are BSPP threads, then I do not know where to get adapters.
Larry C0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
