What kind of fittings
Hi all,
Went to change the pump Fri. and the new pump had a different size fitting, so back in went the old pump.
The fittings seal to the pump with o-rings and do not have tapered threads, though a 3/4 NPT fitting does screw into the threads, but won't seal.
The flange fittings also seal with a o-ring.
Looking for a name that I can call a distributor and ask for a fitting. sometimes describing doesn't quite cut it.
Thanks Don in Mo
  • Larry C_13
    Larry C_13 Member Posts: 94
    BSPP ?
    Could it be BSPP? British Standard Pipe Parallel thread.
    Both NPT and BSP 3/4" pipe has the same thread pitch of 14 TPI. The peaks and valleys of the BSP threads are rounded instead of flattened like NPT.
    Larry C
  • ddlong1286@yahoo.com
    ddlong1286@yahoo.com Member Posts: 139
    You Are Correct!!
    I was able to talk to the manufacturers USA rep today and he told me that they are indeed 3/4 BSP threads in the pump.
    Now if I can find out about the fittings on the old pump and where to get them!
    Don in MO
  • Glen
    Glen Member Posts: 854
    try -
    a hydraulics supply house. Sounds like a JIC fitting with o ring.
  • Larry C_13
    BSP to NPT adapters
    Try the McMaster-Carr site for BSP Tapered to NPT adapters.
    http://www.mcmaster.com/
    If they are BSPP threads, then I do not know where to get adapters.
    Larry C
