Heat loss ?? SE
Mike T., Swampeast MO
Member Posts: 6,928
For whatever reason both conductivity and emissivity specs for PEX and other plastic tubing materials are very hard to find. Without those numbers it's impossible to even make a reasonable guess.
Heat loss ?? SE
Anyone have numbers on heat loss of various uninsulated pipe materials? specifically pex in a 70* air space. I thought that I saw it on Siggy's hydronics design CD but it just has data for copper. I'd like to know what uninsulated pex and PAP are also. I want to show a customer why the suspended tube system recommended by another contractor for his house ain't gonna cut it.0 -
My approach
I wouldn't try and compare designs by the heatloss of bare tube. I would take the heatloss of the space(s) per sq ft and show them required water temp for bare tube vs plates, etc.
When they see, in print, that a proposal won't fly, you're done
Wirsbo deign manual has these charts, I'm sure others' do too.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
