Grunfoss cast body circulator in open loop
These two circulators were run in open loops. They unbelievably still ran after many years of service. Take a look at where you are headed...
  • David Zierke
    David Zierke Member Posts: 19
    I have a subcontractor that wants to use a Grunfoss cast body circulator pump in an open loop heat exchange circuit. Grunfoss says that cast is incompatible in open loop and that either the brass or stainless should be used. If the subcontractor goes ahead with the cast, what can I expect as a result?
    Thank you
  • heatboy
    heatboy Member Posts: 1,468
    Maybe you should......
    ........hire a new contractor? I wonder what else he thinks is OK. Cast Iron + water = Deterioration. Always has, always will.
    Can I have a glass of water? I feel my iron is low ;-)
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    it will work....
    for awhile maybe 6 mo....will he warrantee the work for a year?
  • nosirra1Arrison
    nosirra1Arrison Member Posts: 58
    Here is your proof
    These two Grundfos pumps were run in open loops. They lasted many years and unbelievably still functioned when pulled...Look at the pics and you will see where you are headed.
  • Good question,
    I always kinda wondered that myself,,besides most well-water jet pumps are CI. Then,, if it is bronze or SS the corrosion factor here would be nil.
    Dave
  • Brad White
    Brad White Member Posts: 2,399
    Sort of like God
    creating a human body and installing a cheap heart :)
    It is the heart of your system, that is no place to skimp.
    My $0.02
    Brad
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • David Zierke
    Thank you responders for taking the time
    to respond to my question. The photo's were a great help.
