Help on circa 1870 rads
jeff_51
Member Posts: 545
we don't have alot of old steam systems out here, so what is common to you guys is not common to us. If we get this job, I told the owner I was going to go out and buy a digital camera so I could post some pics of the house and some of those grand old rads
help on circa 1878 rads
doing an EDR calc for a steamer replacement and need help on edr on a couple of old rads. One is 2 column 13 section 36" high and looks like the porcelan isolators on high tension power lines. The columns do not appear to connect at the top. Have a six sided nut cast on top and appear to screw into the base. Have another that is a 2 colum 12 section 33" high by JE Reed Radiator Co. The third is a 2 column 16 section 32" AA Griffing/ Bates & Johnson. Also a 2 column 18 section 36" pipe rad, I know these have been posted before, but don't have that info0 -
Not sure what the first one is
post a pic if you can. The one made by Griffing is a Bundy, and the Reed is, well, a Reed. You can find their ratings here:
http://www.heatinghelp.com/pdfs/92.pdf
Gotta get a Digital cam , Jeff
we wanna see it!!!! . If you need an edr rating, you can get close comparing size to something similar in EDR Book by Dan Mad Dog
yah!! pictures!!
please...please
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
If we get the job
I will definetly get a digi-cam. They did open the home for the home show last year, so even if we don't get it, I will try to get pics. The house had been restored very nicely by the previous owner, and is VERY nice.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
