From our friends at PHP (Dan H.)
DanHolohan
Member, Moderator, Administrator Posts: 16,686
July 9, 2007
Portland, OR:
Precision Hydronic Products introduces a new line of hydraulic separators and canisters ranging from a simple hydraulic separator that provides quick and easy primary/secondary piping to complete canister systems utilizing system and zone pumps.
Seven patent pending products comprise this latest offering from PHP, the industrys most innovative manufacturer. The Mini-Sep, Low-Loss Header, Low-Loss Header Plus, Sep-Can, Sep-Can Plus, and the Allcan complement PHPs existing wall panel/zoning and boilerpak modular systems.
The Mini-Sep and Mini-Sep Plus are economical small hydraulic separators that allows fast completion of primary/secondary piping for many different boilers. Included are an air vent and convenient fill valve. The Min-Sep may be piped from either side to accommodate installation layouts. The Mini-Sep Plus adds and expansion tank and mounting bracket.
To add zoning, the Low-Loss Header (LLH) and Low-Loss Header Plus (LLH-Plus), which can also be piped from either side for primary/secondary piping, provides additional piping for zone supply and return connections. The Low-Loss Header is a basic piping tree that will accept field-installed pumps. The Low-Loss Header Plus is a complete package including a fill valve, expansion tank, pumps, and mounting bracket. The Grundfos® pumps use end-suction flanges to allow for a compact primary/secondary zoning package.
The Sep-Can and Sep-Can Plus are similar to the LLH and LLH-Plus in that they are available as stripped down versions (Sep-Can) and as a complete package including hydraulic separation, air elimination, expansion tank, fill valve, primary and secondary pumps, and mounting bracket (Sep-Can Plus). These units are intended to install under bottom-piped, wall-mounted condensing boilers.
The Allcan completes this product offering. This is a hydraulic separator with a high-quality air separator built-in. It is the space-saving complete solution for any boiler. Using Grundfos® pumps with end-suction flanges allows the top two pumps to be swiveled up and the bottom two pumps to be swiveled down to accommodate installation requirements. The Allcan comes with a wall mounting bracket, fill valve, expansion tank, internal air separator, primary and secondary pumps.
The Low-Loss Header, Low-Loss Header Plus, Sep-Can, Sep-Can Plus, and Allcan include primary loop tees for an indirect water tank kit. Mixing valve kits are available for the Sep-Can Plus, and Allcan. The Allcan may also be used as an injection module by varying its system pumps output with a variable speed controller. An option using Taco in-line pumps is available with all pump packages.
For more information on PHPs new hydraulic separators and canisters, or their wall panels and boilerpaks, contact the factory at 503-445-4188 or visit www.phpinc.us.
Portland, OR:
Retired and loving it.
The Man
We were working at Chevy Chase's house in Westchester Just yesterday and Goldie Hawn was visiting (no lie) but I'm more starstuck to know Dan's on the wall while I am. Keep up your good work Dan.0 -
Thanks.
I'd rather be with Goldie. I still get the shivers when I think of the Laugh In days.Retired and loving it.0 -
Shiver me Timbers
I still get the shivers when I think of the "Overboard" and "Private Benjamin" days. Kurt Russell (a might fine actor in my estimation) is one lucky SOB.
Oh by the Way
It's always nice when The Wall brings new products and manufacturers to the teeming masses.
Thanks Dan, as always.0
