GB142 and Low water cut-off
Empire_2
Empire_2 Member Posts: 2,340
I use and like them. CHeck your local codes as to the position and location of the control. If you read the manual, they state that you should use a shallow tee....Yea I have never heard of this type of tee. But when you add your fe. adapter you can see why the reccomend this type of tee. ALso make sure the control is grounded.
Mike T.....
