GB142 and Low water cut-off
Empire_2
Member Posts: 2,340
I use and like them. CHeck your local codes as to the position and location of the control. If you read the manual, they state that you should use a shallow tee....Yea I have never heard of this type of tee. But when you add your fe. adapter you can see why the reccomend this type of tee. ALso make sure the control is grounded.
Mike T.....
Mike T.....
Brands
I have a low voltage Guard dog. Will that work and what are my fellow heating pros using.
Line Voltage
For a GB142 use a line voltage lwco and wire in before the control/unit.Its a line of defence againts a power surge. You realy can't wire after with a GB but not with a Logomatic ...I0 -
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
