Had to put it down
jim burke
Member Posts: 26
I Just replaced this original blue ray boiler with domestic coil with a new buderus . This was one of the first to be installed on long island and cust. loved it .
if customers only knew...
what having a system of theirs displayed on heating help means for them, they would all demand it - nice job!!0 -
Nice install
Install looks great!Thanks for posting the pictures!0 -
Beautiful work Jim
I'll bet the customer loves this system more than the BY . Steady hot water and a drop in fuel use to boot . We've taken out so many Blueray leakers from basements that were finished off after the install ....... I hope the people who designed it never cross my path . I guess it was a tight fit to the basement ? I see the old oil tank cut the long way .0 -
Clean
Great attention to detail. Painted pipes and everything Nice Nice. Sweet Job.
Jim, Not to nitpick but...I have always been under the impression that your 1 1/2 ball valve shouldn't be between the boiler and the LWCO.
Keith0 -
Keith good catch
actually you are right and I usually put the LWCO where he has the 1 1/2 ball valve I find if air does get in system it short cycle the burner as air goes through the horizontal pipe.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
