amtrol heatmaker leak
joe_14
Member Posts: 138
sounds like tank is history did it have an st domestic expansion tank
joe g
joe g
amtrol heatmaker leaking
amtrol heatmaker leaking , foam rubber insulation wet, cannot find a leak at any of the connections. can this tank be saved?0 -
does not sound good...
is it a boiler mate or a hot watermate? How old? kpc
Amtrol BoilerMate
I assume that there is water leaking from gasket and/or the bolts what the coil bolts into the tank? If that is the case you can feel the steel shell of the tank up around the crown to see if it is hot. If so the internal bottle has failed and the tank needs to be replaced.
How old is this tank? If the tank is not that old there could be other reason's that this bottle failed early. We normally see life spans on the bottle of 14-24 years with normal ussage0 -
no DHW expansion tank, someleak from vent of DCA back flow preventer, unit is 80 gallon boilermate0 -
no expcnsion tank on DHW line, some leak from vent of DCA backflow preventer, this unit is an 80 gallon boilermate0 -
amrtol heatmaker leak
this unit is 8 years old0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
