Buderus Pump Stations
Joe@buderus_2
Joe@buderus_2 Member Posts: 302
The Buderus pump station has many features such as the pressure by valve, shut offs in the supply and return lines, flow check on the supply, temperature gauges to help set delta T, 3 speed Grundfos circulator (90,000 Btu's at 10 feet of head), unionized connections, all in cased in a insulated cover to stop heatloss. We also offer a "mixing station" which has the same features mentioned above along with a motorized mixing valve. Thanks for the input regarding the stations!
