Feed and return on same end?
Ur woory the pipes will freeze? Then the radaitors shudnt be there in 1st place...
Half inch pipe will work in space provided..
Is there a water baseboard heater available with a feed and return on the same end (3/4)? I looked at mine and the brackets seem to be in the way to do it myself. I have a room over a slab that needs heat and I am afraid to pipe it underneath for fear of freezing.
Tom0 -
Most
baseboard has a arched area in the brackets above the fin/tube that a 3/4 copper pipe will rest in for a return.
Bruce0 -
freezing?
Half inch pipe will work in space provided..0 -
return
As bruce stated most have space for a return above the element but in the rare case where there is no room on top you can ussually run it under the brackets although this may show when standing across the room.There was an error rendering this rich post.
- 50 Industry Classes
