Feed and return on same end?
Ur woory the pipes will freeze? Then the radaitors shudnt be there in 1st place...
Half inch pipe will work in space provided..
  • tom_75
    tom_75 Member Posts: 13
    Is there a water baseboard heater available with a feed and return on the same end (3/4)? I looked at mine and the brackets seem to be in the way to do it myself. I have a room over a slab that needs heat and I am afraid to pipe it underneath for fear of freezing.
    Tom
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    Most
    baseboard has a arched area in the brackets above the fin/tube that a 3/4 copper pipe will rest in for a return.
    Bruce
  • freezing?
  • JK_3
    JK_3 Member Posts: 240
    return
    As bruce stated most have space for a return above the element but in the rare case where there is no room on top you can ussually run it under the brackets although this may show when standing across the room.
