Commercial Electric Hot water Boiler
Glenn Sossin_2
Member Posts: 592
Would you consider LP as a possibility. It would probably save 30% -65% on your fuel depending on KWH rate you get. I am assuming the 477k is meant to be 477,000 btuh, or is that 477 kwh?
Commercial Electric Boiler Reccomendations
Have a customer looking at a job that is needing 466K of slab radiant heat. Any electric boilers that someone would reccomend for a job this size. I have only dealt with the under 100K models.
Thanks,
Rob0 -
You might try a Google Search ...
under: "electric boilers"
It might make sense to use a few smaller boilers and "stage them" based on how cold it is out.
Unless you can buy electricty at well under 10-cents/KW, Oil, NG or LP would be less expensive to run.
Let us know how it goes.
Precision makes a nice electric boiler. You can get them with multiple stages.0 -
Sussman, Argo and Precision
come to mind."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 167 Indoor-Air Quality
