Commercial Electric Hot water Boiler
Glenn Sossin_2
Glenn Sossin_2 Member Posts: 592
Would you consider LP as a possibility. It would probably save 30% -65% on your fuel depending on KWH rate you get. I am assuming the 477k is meant to be 477,000 btuh, or is that 477 kwh?
  • Rob Blair
    Rob Blair Member Posts: 227
    Commercial Electric Boiler Reccomendations
    Have a customer looking at a job that is needing 466K of slab radiant heat. Any electric boilers that someone would reccomend for a job this size. I have only dealt with the under 100K models.
    Thanks,
    Rob
  • Ken_40
    Ken_40 Member Posts: 1,310
    You might try a Google Search ...
    under: "electric boilers"
    It might make sense to use a few smaller boilers and "stage them" based on how cold it is out.
    Unless you can buy electricty at well under 10-cents/KW, Oil, NG or LP would be less expensive to run.
    Let us know how it goes.
  • Josh_10
    Josh_10 Member Posts: 786
    Precision makes a nice electric boiler. You can get them with multiple stages.
  • Brad White
    Brad White Member Posts: 2,399
    Sussman, Argo and Precision
    come to mind.
    -Ernie White, my Dad
