Taco IFC
chuck172
chuck172 Member Posts: 90
Where are the check valves on the taco 007 pumps? Outlet or inlet?
  • Rich Ferris
    Rich Ferris Member Posts: 72
    Taco IFC
    Taco 007 IFC check valves are on the outlet of the pump. They are removable. Why are you asking? Are you having (Ghost) flow?
  • chuck172
    No, I was just curious, thanks.
  • bob eck
    bob eck Member Posts: 930
    gheck out the grundfos suberbrute circulators.
    check valve in installed on the outlet side of the pump. can be removed. this circulator has three speeds.
    comes with a full three year warranty.
    the ups15-58fc delivers mor gpm and higher head than a taco.
    check out grundfos.
  • Not to split hairs Robert,
    but the Taco OORIFC 3 speed is slightly higher flow, and also has a 3yr warranty.
    Besides, I`m kinda partial to the color green.
    Dave
