Taco IFC
chuck172
Member Posts: 90
Where are the check valves on the taco 007 pumps? Outlet or inlet?
Taco IFC
Taco 007 IFC check valves are on the outlet of the pump. They are removable. Why are you asking? Are you having (Ghost) flow?0 -
No, I was just curious, thanks.0 -
gheck out the grundfos suberbrute circulators.
check valve in installed on the outlet side of the pump. can be removed. this circulator has three speeds.
comes with a full three year warranty.
the ups15-58fc delivers mor gpm and higher head than a taco.
check out grundfos.0 -
Not to split hairs Robert,
but the Taco OORIFC 3 speed is slightly higher flow, and also has a 3yr warranty.
Besides, I`m kinda partial to the color green.
Dave0
