beckett oil burner
mtfallsmikey
Member Posts: 765
This is probably the dieletric from the capacitors(??)but I thought the new ignitors were epoxy packed. The transformers from older burners would ooze brown goo sometimes...when I was young, they had PCB's...(geez alert!)
beckett oil burner
I have a beckett burner with a capacitor dripping oil. the unit is less than a year old. mn: af 11 100 ,is this a common issue? Is there a common micro ferad aftermarket replacement that fits in the cover. Any disasembly tips would be helpful.0 -
I've
never seen that.Are you sure it's not an fuel oil leak?All Beckett components have a 5 year warranty
beckett burner
definitly not fuel oil. Very thick sticky clear odorless oil. The capacitor sits directly under the motor with a plastic cover.0 -
PSC Motor
Is this a PSC motor?0
- 167 Indoor-Air Quality
