beckett oil burner
mtfallsmikey
Member Posts: 765
This is probably the dieletric from the capacitors(??)but I thought the new ignitors were epoxy packed. The transformers from older burners would ooze brown goo sometimes...when I was young, they had PCB's...(geez alert!)
beckett oil burner
I have a beckett burner with a capacitor dripping oil. the unit is less than a year old. mn: af 11 100 ,is this a common issue? Is there a common micro ferad aftermarket replacement that fits in the cover. Any disasembly tips would be helpful.0 -
I've
never seen that.Are you sure it's not an fuel oil leak?All Beckett components have a 5 year warranty
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
beckett burner
definitly not fuel oil. Very thick sticky clear odorless oil. The capacitor sits directly under the motor with a plastic cover.0 -
PSC Motor
Is this a PSC motor?0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
