automatic water feeder on a steam system?
Garret
Member Posts: 111
Greetings gents...
When replacing a boiler on a small, residential, two-pipe steam vapor system, is it a good idea to install an automatic water feeder? Our old boiler has a McDonnell & Miller manual feeder with low-water cutoff.
Seem to me that you'd want to know when a steam boiler is using up water because it's adding oxygen to the system. I'd be doing routine blowouts anyway, so adding a little more water isn't a big deal.
Also, I'd think when combining an old steam system and a new boiler, you'd run the risk of the autofeeder kicking in if the boiler's water level drops a bit when it's filled up the pipes with steam. Then you'd flood the boiler when the condensate returns...
The only advantage I can think of for an auto feeder is that you don't run the risk of the phone ringing when you turned the supply valve on... Yah, I've done that... once!
-Garret
-Garret
Electronic Feeders
The new electronic feeders are low volume fill ,made for newer boilers.Some have volume setting and a meter clock. They just about all have delays for sluggest condonsate return. But your right steam is still a hands on system.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
