mechanical steam piping fittings
TJ_5
Member Posts: 71
Try a dresser fitting. They make a steam rated coupling. www.dressercouplings.com
mechanical fittings for steam
I have a 2.5" sch. 40 steam main in a difficult location to weld. The pipe is leaking. I'm looking for a mechanical coupling or adapter rated for steam to get to NPT. Does this fitting exist? Victaulic said their fittings are not rated for steam. Thank you for your anticipated help. John Phillips0 -
consider one or a pair of flange unions .0
- 87.1K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
