mechanical steam piping fittings
TJ_5
TJ_5 Member Posts: 71
Try a dresser fitting. They make a steam rated coupling. www.dressercouplings.com
  • John Phillips
    John Phillips Member Posts: 2
    mechanical fittings for steam
    I have a 2.5" sch. 40 steam main in a difficult location to weld. The pipe is leaking. I'm looking for a mechanical coupling or adapter rated for steam to get to NPT. Does this fitting exist? Victaulic said their fittings are not rated for steam. Thank you for your anticipated help. John Phillips
  • bob young
    bob young Member Posts: 2,177
    consider one or a pair of flange unions .
