Taco water feeders
ken_36
ken_36 Member Posts: 17
Has anyone had a problem with the single Taco boiler water feeder leaking at the square body gasket?
  • Big Ed
    Big Ed Member Posts: 1,117
    body gasket
    Yes for years now you return to the job to find a leaker.Need to tighten the four screws when installing a new valve....
  • Only seen it
    on boilers with alot of makeup water going in for a while . Most common is in a house with leaking radiant , usually going on for months before someone catches it .
  • Joe Mattiello_2
    Joe Mattiello_2 Member Posts: 94
    Not at the factory
    No histor of any problems with leaking water feeders. I will be happy to talk to anyone that does have a problem.
    Joe Mattiello
    Technical Support Technician
    Tel. 401-942-8000 X 484
    Fax. 401-942-2360
    1160 Cranston St
    Cranston, RI 02920
    joemat@taco-hvac.com
