Taco water feeders
ken_36
Member Posts: 17
Has anyone had a problem with the single Taco boiler water feeder leaking at the square body gasket?
body gasket
Yes for years now you return to the job to find a leaker.Need to tighten the four screws when installing a new valve....0 -
Only seen it
on boilers with alot of makeup water going in for a while . Most common is in a house with leaking radiant , usually going on for months before someone catches it .0 -
Not at the factory
No histor of any problems with leaking water feeders. I will be happy to talk to anyone that does have a problem.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0
- 114 Geothermal
