\"Blowing off\" the boiler
John H.
John H. Member Posts: 38
> I have a Utica steam boiler that is oil-fired. <BR>
> My question has to do with "blowing off" the <BR>
> boiler.<BR>
> <BR>
> I know I'm supposed to drain some of <BR>
> the boiler water periodically to allow the <BR>
> sediment and sludge to escape. But how much of <BR>
> this water am I actually supposed to drain out? <BR>
> For the past couple of winters I've been draining <BR>
> the entire boiler and refilling it once a week or <BR>
> so because the water in the guage glass looks <BR>
> especially dirty after a week. I've heard you <BR>
> should do this once a month, but that seems too <BR>
> long. Am I doing anything wrong, here?<BR>
> <BR>
> TF <BR>
<BR>
  • Toolfreak
    Toolfreak Member Posts: 10
    \"blowing off\" the boiler
    I have a Utica steam boiler that is oil-fired. My question has to do with "blowing off" the boiler.
    I know I'm supposed to drain some of the boiler water periodically to allow the sediment and sludge to escape. But how much of this water am I actually supposed to drain out? For the past couple of winters I've been draining the entire boiler and refilling it once a week or so because the water in the guage glass looks especially dirty after a week. I've heard you should do this once a month, but that seems too long. Am I doing anything wrong, here?
    TF
  • John H.
    1 time
    every week you need to flush the Low Water Cutt Off If you have the type with a flush valve. Just flush untill the water is somewhat clear. Also try and do it when the boiler is running the boiler should shut down when you open the valve.
  • ken_36
    ken_36 Member Posts: 17
    You don't want to drain the whole boiler that often. Steam boilers don't like alot of makeup water. The manufacturer has a strict amount of water that should be introduced into any given steam boiler.
  • ken_36
    Maybe the crud is coming from the returns? Have thayever been flushed out or inspected?
