\"Blowing off\" the boiler
John H.
Member Posts: 38
> I have a Utica steam boiler that is oil-fired. <BR>
> My question has to do with "blowing off" the <BR>
> boiler.<BR>
> <BR>
> I know I'm supposed to drain some of <BR>
> the boiler water periodically to allow the <BR>
> sediment and sludge to escape. But how much of <BR>
> this water am I actually supposed to drain out? <BR>
> For the past couple of winters I've been draining <BR>
> the entire boiler and refilling it once a week or <BR>
> so because the water in the guage glass looks <BR>
> especially dirty after a week. I've heard you <BR>
> should do this once a month, but that seems too <BR>
> long. Am I doing anything wrong, here?<BR>
> <BR>
> TF <BR>
<BR>
> boiler.<BR>
> <BR>
> <BR>
> TF <BR>
<BR>
\"blowing off\" the boiler
I have a Utica steam boiler that is oil-fired. My question has to do with "blowing off" the boiler.
I know I'm supposed to drain some of the boiler water periodically to allow the sediment and sludge to escape. But how much of this water am I actually supposed to drain out? For the past couple of winters I've been draining the entire boiler and refilling it once a week or so because the water in the guage glass looks especially dirty after a week. I've heard you should do this once a month, but that seems too long. Am I doing anything wrong, here?
TF0 -
1 time
every week you need to flush the Low Water Cutt Off If you have the type with a flush valve. Just flush untill the water is somewhat clear. Also try and do it when the boiler is running the boiler should shut down when you open the valve.0 -
You don't want to drain the whole boiler that often. Steam boilers don't like alot of makeup water. The manufacturer has a strict amount of water that should be introduced into any given steam boiler.0 -
Maybe the crud is coming from the returns? Have thayever been flushed out or inspected?0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
