hot water heat
tim bushaw
Member Posts: 1
Dear Sir,
I have excessive gugling and sloshing in my radiators. Had a flush and refill of pipes 2 weeks ago, it helped but was temporary. Furnace repair person said a valve which adds water to system when needed may be bad. Could you explain to me how this valve works and proper name please. Plan on furnace replacement this summer as present unit 40 years old. Thank you. Tim.
PRV
Sounds like he is talking about a pressure regulator valve which, steps the incomming water pressure from a higher pressure to a lower pressure. Usually preset @ 12 psi. SOunds like your radiators need to be bled. What is the current pressure reading on the boiler itself? Water pressure is used to raise the water level in the house. 1 psi =2.34 feet from where valve sits.0
