Steam question
Steamhead (in transit)
Member Posts: 6,688
the water shouldn't back up that high. Since it is, you either have a plugged return or check valve or a bad Return Trap, or maybe the Pressuretrol is set too high.
A Gorton #2 main vent would work in its place, but if the water is backing up that high it will close that unit too. Find and fix the problem.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Steam Question
Apartment building, Steam system, 1 pipe with a Dunham #220 float type vent on the return pipe at ceiling in boiler room. float valve is shot, leaking through valve seat. Any ideas on functional replacement for this. This is a vapor system per the "book".0 -
Thanks for the reply Steamhead.
I will look into the main return trap and check for blockage.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
