Any source for eccentric reducers?
Daniel_3
Member Posts: 543
I live in Woosta, MA =)
Black malleable iron 2" x 1" ?0 -
We can get them in Baltimore
tell us where you are, and someone may know who carries them.
This is for a steam system, right?
Actually I don't need them now. I just finished piping in that Gorton menorah we had talked about
A 45^ off the end of the main feeding to the dry returns would have needed them but I used two hexagon bushings instead and it creates no problem as I had thought it might since the angulation does not restrain the condensate return (it moves 45^ down). Had I used the eccentric reducer it would have looked better but costed more money. I used a 2-1 1/2 then a 1 1/2-1. A 2-1 bushing may have had too steep of a lip after the interior threads and created a little puddle. I used a 2x2x3/4 tee at each end of the main but had to plug one (couldn't return it to the purchasee) and ran a 1x1x3/4 between the 90^ at the main and the 90^at the return. That plugged tee had no way of having a vent off it since it butted up almost right against a cross beam. Thanks for the response Frank. 0 -
cleveland plumbing supply
has them if your around cleveland ohio.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
So
how much better does the system work now?
I thought is was "Wista"... I'm now in Braintree, formerly of "Quinzee"!0 -
And I thought this thread all meant
that the beloved Weezbo was going on a diet.
eccentric reducers...
good one
Well . . . . .Right now where the boiler was, there is no boiler so until a boiler gets there we won't know just yet, but I say it will happen in about a week or two.
Wista to those in Bawstin but Woosta to those in Worcester. Kwincey to me though
I always wondered how they came up with the name "Braintree", kinda scary. 0 -
Insult?
Sometimes the things that work best are those that run a tad off center, just like Weez.0 -
Which is why
I consider Weezbo essential.
You live in Woosta ? You have to try Charles Manoog Supply if any one in your city has them they will.They are also the home of the American Sanitary Plumbing Museum.0
- 167 Indoor-Air Quality
