Any source for eccentric reducers?
Daniel_3
Daniel_3 Member Posts: 543
I live in Woosta, MA =)
  • Daniel_3
    Black malleable iron 2" x 1" ?
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    We can get them in Baltimore
    tell us where you are, and someone may know who carries them.
    This is for a steam system, right?
  • Daniel_5
    Daniel_5 Member Posts: 4
    Actually I don't need them now. I just finished piping in that Gorton menorah we had talked about =) A 45^ off the end of the main feeding to the dry returns would have needed them but I used two hexagon bushings instead and it creates no problem as I had thought it might since the angulation does not restrain the condensate return (it moves 45^ down). Had I used the eccentric reducer it would have looked better but costed more money. I used a 2-1 1/2 then a 1 1/2-1. A 2-1 bushing may have had too steep of a lip after the interior threads and created a little puddle. I used a 2x2x3/4 tee at each end of the main but had to plug one (couldn't return it to the purchasee) and ran a 1x1x3/4 between the 90^ at the main and the 90^at the return. That plugged tee had no way of having a vent off it since it butted up almost right against a cross beam. Thanks for the response Frank.
  • gerry gill
    gerry gill Member Posts: 3,078
    cleveland plumbing supply
    has them if your around cleveland ohio.
    gwgillplumbingandheating.com
  • Hvacman
    Hvacman Member Posts: 159
    I thought is was "Wista"... I'm now in Braintree, formerly of "Quinzee"!
  • Brad White_172
    Brad White_172 Member Posts: 53
    And I thought this thread all meant
    that the beloved Weezbo was going on a diet.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    eccentric reducers...
    good one :)
  • Daniel_3
    Well . . . . .Right now where the boiler was, there is no boiler so until a boiler gets there we won't know just yet, but I say it will happen in about a week or two. =)
  • Daniel_3
    Wista to those in Bawstin but Woosta to those in Worcester. Kwincey to me though =) I always wondered how they came up with the name "Braintree", kinda scary.
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Insult? ;)
    Sometimes the things that work best are those that run a tad off center, just like Weez.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Which is why
    I consider Weezbo essential. :)
  • Lyle C
    Lyle C Member Posts: 96
    You live in Woosta ? You have to try Charles Manoog Supply if any one in your city has them they will.They are also the home of the American Sanitary Plumbing Museum.
