Any source for eccentric reducers?
Daniel_3
Member Posts: 543
I live in Woosta, MA =)
Black malleable iron 2" x 1" ?0 -
We can get them in Baltimore
tell us where you are, and someone may know who carries them.
This is for a steam system, right?
Actually I don't need them now. I just finished piping in that Gorton menorah we had talked aboutA 45^ off the end of the main feeding to the dry returns would have needed them but I used two hexagon bushings instead and it creates no problem as I had thought it might since the angulation does not restrain the condensate return (it moves 45^ down). Had I used the eccentric reducer it would have looked better but costed more money. I used a 2-1 1/2 then a 1 1/2-1. A 2-1 bushing may have had too steep of a lip after the interior threads and created a little puddle. I used a 2x2x3/4 tee at each end of the main but had to plug one (couldn't return it to the purchasee) and ran a 1x1x3/4 between the 90^ at the main and the 90^at the return. That plugged tee had no way of having a vent off it since it butted up almost right against a cross beam. Thanks for the response Frank.
cleveland plumbing supply
has them if your around cleveland ohio.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
So
how much better does the system work now?
I thought is was "Wista"... I'm now in Braintree, formerly of "Quinzee"!0 -
And I thought this thread all meant
that the beloved Weezbo was going on a diet.0 -
eccentric reducers...
good oneThere was an error rendering this rich post.
Well . . . . .Right now where the boiler was, there is no boiler so until a boiler gets there we won't know just yet, but I say it will happen in about a week or two.0 -
Wista to those in Bawstin but Woosta to those in Worcester. Kwincey to me thoughI always wondered how they came up with the name "Braintree", kinda scary.
Insult?
Sometimes the things that work best are those that run a tad off center, just like Weez.0 -
Which is why
I consider Weezbo essential.0 -
You live in Woosta ? You have to try Charles Manoog Supply if any one in your city has them they will.They are also the home of the American Sanitary Plumbing Museum.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
