No heat(Brrrrrrrrr)
use or borrow a digital camera, take a few pictures and attach them to a follow up post. It often is very informative even if you can't answer the questions.
jerry
  • TARASA
    TARASA Member Posts: 1
    NO HEAT(BBBRRRRRRRRRRRRRRRRRR)
    I RECENTLY MOVED HERE FROM MN, AND MY HEAT WENT OUT IN MY HOUSE...THE FAN IS KICKING ON BUT IT IS BLOWING OUT COOL AIR..DO YOU THINK ITS A PROBLEM WITH BOILER AND/OR FURNACE? WHAT STEPS SHOULD I TAKE TO FIX IT W/O IT BEING TOO EXPENSIVE, IF ANY?
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    A brand name with
    a model and serial number of your unit would be a good start to any of us being able to help you. Also, just to make sure, do you have a furnace, a unit that heats the air, a boiler, which heats water, or a hydro air system where a boiler heats water and pumps it to an air handler which then blows the heat into the house.
  • Weezbo
    Weezbo Member Posts: 6,231
    Big metal box wit a couple big metal boxes
    or a boiler with black pipes and copper pipes ? do you have a gas bill or a fuel oil bill?
    Or neither of the above?........:)
  • Weezbo
    I got to think if it was forced air....
    she is as blue as the summer sky ,right about now .
